2520 getting into gear
   / 2520 getting into gear #1
vintagemilano
Cranbrook, BC
JD 2520
On my recently arrived 2520 I find that it is rather notchy going from N to either H or L, sometimes requiring playing with the forward and reverse pedal to get the gear selector to click into position. Is this normal? I would have thought that slip into gear should be the norm as opposed to give a good push and click into gear after some fiddling.
Here's a pic, http://farm1.static.flickr.com/212/479150784_c856c6eab1_b.jpg
Thanks, Carson
   / 2520 getting into gear #2
I sure hope it's normal, mine has the same behavior. It's become second nature to get it in gear, so it doesn't bother me much.
   / 2520 getting into gear #3
Yes it is normal. you haft to let the gears mesh.
all of them do that..;)
   / 2520 getting into gear #5
They're all straight-cut gears in the tranny, so you need to get them lined up. You're best by using very light pressure on the gear selector, and also just touching the pedals.
   / 2520 getting into gear #6
I used to have a 755 and didn't have to put it in N every time I got off the seat with it running, just set the parking brake. I suppose its a good safety feature on my 2520, but kind of a PITA. A couple times on the 2520 I've got on, released the parking brake, haven't touched the hydro pedals and just start rolling! Dummy me, I forget to put it back in gear! Like I said, to me still used to the 755 its a PITA.
Anyway, I've found that if on level ground, I just turn the steering a little to the left or right while shifting out of N and it moves things just enough to mesh the gears.
   / 2520 getting into gear #7
I jumpered the seat switch on my 2520, so I can let it in gear and get off of it. I know its not as SAFE, but its my way! :cool:
   / 2520 getting into gear #8
I will most likly do the same. i am not the tallest guy in the world. and when you are trying to ease pallet forks under something i always stand up. and it kills the engine. drives me crazy...:rolleyes:
   / 2520 getting into gear #9
Is there some law which makes it mandatory that tractors be equipped with an operator presence switch? I can understand why mowers are equipped with it and I can understand if a mower is running on a tractor, that it would be safer, but like Chris said, there are times when I would like to stand up to be able to view something better and I can't do it. I was thinking about jumpering around it as well. I understand the implications, but let's face it, when you're working around equipment like this, there's lots of ways to get hurt if you're not thinking.
   / 2520 getting into gear #10
There are more laws than you could shake a stick at, but I think this has to do with the manufacturer's liability and not wanting to get sued by stupid people. I think it's more the fault of the legal system than anything else.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
REIST R25PSS LOT IDENTIFIER 216 (A53084)
REIST R25PSS LOT...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
