2520 Front / Rear work lights but not both?
   / 2520 Front / Rear work lights but not both? #1
bheston
I ordered front work lights for my future 2520 but the dealer says the rear work light is not compatible if you install the front work lights. Is that true?
   / 2520 Front / Rear work lights but not both? #2
Maybe they're both wired to the same plug ?
Have checked the JD parts page for any clues ?
   / 2520 Front / Rear work lights but not both? #3
I got 2 in front and back - have the rear on a separate switch (Chris2520) has pics of his install. I also went up to the larger 35 amp alternator. Hope that helps, Brad
   / 2520 Front / Rear work lights but not both? #4
Your dealer is talking about plug and play. and he is right. you can only add 2 extra work lights. by plug and play. what i mean is. the harness. is prewired for 2 AUX lights. that come on useing the headlight switch. So tell him you want 2 extra rear work lights. wired on a seperate switch . mount the switch on the PTO console. and it will be wired seperately. now you will have 2 extra foward lights. and 2 rear work lights. this is how mine is done. and it works great....;)
Chris.....:)
   / 2520 Front / Rear work lights but not both? #5
One place on JD site says not compatible with each other, another says they are.
So I gambled and got both a few months ago. After installing two forward and one rear lights, I still have one connection point that could be made up, and I only used what came in the standard kits. (kit includes "y" connections.)
   / 2520 Front / Rear work lights but not both? #6
Your right Yash , thats why the rears need to be on a seperate switch. besides. you dont need the fronts and rears on at the same time. i also have the high output alternater....;)
Chris....:)
   / 2520 Front / Rear work lights but not both? #7
Chris... I can guess that it's likely been a spell since you had to plow snow in the dark of night in Georgia...!
But if that snow is comin' down hard and it's dark --- you'll want those rear light's on to keep from backin' into the peach tree!
AKfish
   / 2520 Front / Rear work lights but not both? #8
AKfish
Well AKfish , You would be most correct. I never thought of it that way. because where i live. That place very deep in the ground we dont speak of , would most likely freeze over before we get to see any Snow.....:D we might get a tad of freezing rain once a year. but the last real snow. i mean 5 inches or more was 1987. I remember rideing 4 wheelers on the streets. that was fun. and then no more snow for 20 years....:( A snow blower here is considered an Antic...:D But you are right. But all i would haft to do is reach to my left and flip a switch. and i can light up the heavens with 2 rears and 4 front lights.....;) but i do realize where you live. Snow is probebly more common than Grass....:p
Chris.....:)
Giyi 27" Mixing Bucket (A53316)
Giyi 27" Mixing...
2002 International 4300 DT466 (A53314)
2002 International...
2023 HLMK TL (A55758)
Rain-Flo Vegetable Transplanter (A53314)
Rain-Flo Vegetable...
Mini Plate (A53316)
Mini Plate (A53316)
2010 Chevy Express Van (A47477)
2010 Chevy Express...
