2520 62D and Quick Hitch Compatibility Issue?
/ 2520 62D and Quick Hitch Compatibility Issue? #1
Holiday
Michigan
JD 2305
Has anyone come across a compatibility issue with the 62D deck and the front quick hitch on their 2520? When I drop the deck and go to put on the front quick hitch the attaching parts do not match up. The bracket to attach the 62D need to be removed and a different bracket put on to mount the quick hitch. I don’t see how the brackets can be on together. Did I miss something here? Also the hood guard which uses the same bolts as the brackets will not go on with the quick hitch attaching parts in place.
Am I doing something wrong? Has anyone found this issue and know of a fix? /forums/images/graemlins/confused.gif
