Loader 250TL
   / 250TL #1
alakodiak
LA - Lower Alabama
New Holland TC35D
Looking for anyone with a 250TL loader. I just got mine and love it but want to make sure I have it attached correctly. When looking at the tractor from the front the left side cam pin is in the whole closest to the back of the tractor and the right side cam pin is in the whole closest to the front of the tractor. Is that right or have I messed something up?
Thanks,
John
   / 250TL #2
It doesn't matter which hole the pin is in as long as there is no slop or rattle in the pin. If you look on the cam lever there are like four bolt holes to adjust as the cam wears just remove the bolt and move to a different hole to adjust. When you put the loader on push the cam lever til the pin is tight then put in the lock pin. If you cant get it tight move the bolt in the cam lever to a different hole.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
JMR stump/trenching bucket (A53421)
JMR...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
