Loader 250TL
   / 250TL #1
alakodiak
LA - Lower Alabama
New Holland TC35D
Looking for anyone with a 250TL loader. I just got mine and love it but want to make sure I have it attached correctly. When looking at the tractor from the front the left side cam pin is in the whole closest to the back of the tractor and the right side cam pin is in the whole closest to the front of the tractor. Is that right or have I messed something up?
Thanks,
John
   / 250TL #2
It doesn't matter which hole the pin is in as long as there is no slop or rattle in the pin. If you look on the cam lever there are like four bolt holes to adjust as the cam wears just remove the bolt and move to a different hole to adjust. When you put the loader on push the cam lever til the pin is tight then put in the lock pin. If you cant get it tight move the bolt in the cam lever to a different hole.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2017 Ford Explorer (A50324)
2017 Ford Explorer...
2 Row Custom Produce Cultivator (A52128)
2 Row Custom...
