2501D
/ 2501D #1
Ceriusone
central South Carolina
Mitsubishi 2501D
Hi. I purchased a Mitsubishi 2501D last October. When I bought this tractor, I discovered that it had a blown head gasket and kept over pressurizing the radiator and blowing out all of the coolant. I contacted the person who sold me the tractor and he carried it to his mechanic and had it “fixed”. Anyway, once I got it back, it ran great for about two days (though I only ran it for about 30 minutes each time), and then it started doing the same thing again. Is this a common problem with this tractor? Is there something special I should know that would solve this problem? How difficult is this job to "do" yourself with some mechanical background? Thanks for any input.
/ 2501D #2
You may have to have the head checked to see if it needs to be trued. Sounds like it might be warped a tad. Or cracked? Pressure test it. Or the top of the block is warped but I doubt it. I wonder if they used the correct gasket? You can do this yourself with the proper manual. However you need a machine shop to check the head.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
Unused 2023 Hustler LX890 235 Gallon Sprayer Tractor Attachment (A66734)
Unused 2023...
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
