25 hp, 3 cyl. Ladong Engine replace
/ 25 hp, 3 cyl. Ladong Engine replace #1
Lodi
walworth WI.
Lu Zhong
I have a 2007 Luzhong 254 with ladong engine. I also have a new engine still in the crate. I have stage 4 cancer and wish to change out that old engine while I can still get around. I think the Luzhong is similar to the Nortrac tractors. Does anyone here know if I can just lift the engine off of the tractor frame
or do I need to prop up the front axle. It looks like I just need to remove battery and radiator and everything in front of engine and then unbolt engine and lift it out of the tractor frame.
I'm hoping maybe someone here has done this before. Thanks for your time.
/ 25 hp, 3 cyl. Ladong Engine replace #2
I have NOT done this on your tractor, but....
You need to "SPLIT the Tractor" at the transmission/clutch bell housing in order to remove the engine. It's not like a car where the transmission can be rocked back to allow the engine to lift free.
Many tractors with frames that carry the engine have bolt up sections where that frame joins the the transmission and rear axle members.
Likely you need to "prop up" the rear of the tractor at the bell housing, and put the front end, including the engine. on wheels to pull it forward and away from the rear.
I could be all wet. but ....I have split more than a few tractors to work on the engines,
and I have NOT stayed at a Holiday Hotel. ;-)
/ 25 hp, 3 cyl. Ladong Engine replace #3
does anybody know where i can get a crate engine for a luzhong 254
possibly a ladong engine, but im happy to get any engine that will fit. (big hole in the crank case )
2013 FORD F-450XL SUPER DUTY DUMP TRUCK (A64277)
2013 FORD F-450XL...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
Husqvarna MZ61 Zero Turn (ZTR) Mower (A66285)
Husqvarna MZ61...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
