25 Acres worth buying hay equipment?
   / 25 Acres worth buying hay equipment? #81
Has anyone talked about how haying is mining minerals and fertility from your land and shipping it down the road? And no chemical fertilizer does not replace it. So haying is a losing money operation and it mines your land.
Taking only 1 cutting per year instead of 2 or 3 helps a lot. Putting cows on the land in between cutting helps as well.
This is true.
I hay to feed cattle, which in turn generate manure which gets spread on the field.
The fields that get manured every year yield very well, the ones that don't, need fertilized, limed reseeded.
   / 25 Acres worth buying hay equipment? #82
I add about 2 tons/acre of spent mushroom compost to my fields.
Does that get me off the Environmentalist’s shitlist?
   / 25 Acres worth buying hay equipment? #83
I think you are taking my comment the wrong way. Just so you know I am a small dairy farmer and go through up to 125 bales a year. Nothing wrong with hay and I know just as much as anyone that it is essential for raising ruminants. I have no disrespect for hay farmers.
Sounds like you are on the right track by putting compost on your fields, more than I can say about most the farmers around here. Also, I think you hay a lot of lease land don't you? That is different than owned land. If people are happy to have there land hayed and hauled off and don't think twice about it well so be it.
   / 25 Acres worth buying hay equipment? #84
Its important to add nutrients to the soil to keep your yields up!
   / 25 Acres worth buying hay equipment? #85
This is interesting. I have depleted my hay fields because of high clay content and high magnesium content. last year i bushogged half of 2 fields instead of taking a last cut. I’m watching now to see if there is any difference.
   / 25 Acres worth buying hay equipment? #87
With a manure spreader?
yep
A real big one…
   / 25 Acres worth buying hay equipment? #88
Wow you live in a for real mansion.
   / 25 Acres worth buying hay equipment? #89
Ummmm, no lol
Thats not my mansion, that is a DuPont mansion.
   / 25 Acres worth buying hay equipment? #90
Looks like you live in the high rent district.
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2019 Ford F-350 4x4 Flatbed Truck, VIN # 1FDRF3HT7KDA15849 (A51572)
2019 Ford F-350...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
