Oil & Fuel 2445's Deutz Diesel won't start
   / 2445's Deutz Diesel won't start #11
Re: 2445\'s Deutz Diesel won\'t start
</font><font color="blue" class="small">( I always thought toggles were cool. I remember nearly drooling when I saw my first Jag XKE. All those toggles... /forums/images/graemlins/cool.gif
I wonder if the key left on fried the engine shutoff switch? )</font>
Hum, inexperienced user drives tractor and it fails. Sounds like a possibility to me.
Bob Rip
   / 2445's Deutz Diesel won't start #12
On my 1430, you can here the fuel switch/solenoid kicking in and out when you turn the key on and off. I suppose leaving the key on for an extended period of time could fry the switch but I don't think so because it's designed to be operated all the time that the tractor is running which could easily be all day and at high temps.
I would first, turn the key on and see if you can here the switch operating. If not, try to apply battery to it with a jumper. If it don't pull up it's probably burned out. I suppose even if it does operate there could still be a mechanical issue causing fuel not to pass. OK, I'm starting to ramble so I'll get out of here.
I've come to believe that "rambling on" is a recognized diagnostic technique on TBN...contributions and insights in any form are welcome when one wants to learn, neh?
The click is gone. I assume this means either 1) the 12 volts that flow through in #7 to energize the engine shutoff switch are not there (possible bad ignition mechanism), or 2) the switch is dead. As Sedgewood observed, it is probably the latter /forums/images/graemlins/frown.gif
Sabi
Spiffy - I went with the PT model ignition switch out of expediency. I thought about NAPA or such, but didn't go there.
Bob- I don't know how I would go about checking fuel flow with the engine shutoff switch off....that said, if it is currently actaully busted or not charged, the fuel is still flowing through /forums/images/graemlins/confused.gif How's that for left handed diagnostics?
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
Little Wonder High Performance Walk-Behind Leaf Vacuum (A55851)
Little Wonder High...
24" EXCAVATOR BUCKET (A52707)
24" EXCAVATOR...
2019 JOHN DEERE 245G LC EXCAVATOR (A52707)
2019 JOHN DEERE...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
2018 Chevrolet...
