2430/304 clutch removal/replace
/ 2430/304 clutch removal/replace #1
2rex2
Michigan
FarmPro 2430/304 mfd, 02
any experiance with dual-stage clutch replacement? remove engine or split tractor
/ 2430/304 clutch removal/replace #3
did'nt have the time to research, but , treated it the same as when i split my backhoe. blocked the front and used a rolling floorjack for the back. to speed it up, just cut the cowl,forward of the instruments and steering colume, a couple of "nice" splice plates will take care fo that. Olnly took a couple of hours, now waiting for parts.
/ 2430/304 clutch removal/replace #5
Ouch! I think I would have taken the extra 30 minutes to remove it all. My luck I wold have cut every wire in there.
Chris
I hear that, but the cut was at a position where the cowl necks down to its smallest, mid way between the tank and front. The nice part is now to gain access to batteries, radiator, hydraulic tanks, i now only remove 2 screws at the bottom front and a couple at the new splice. great for service. As far as wire,,,,,,all now have quick disconnects at the splice, and don't have to remove/mark attach points. coud have installed "camlocks" but only a couple of screws. Terry
