2410 vs 2710/2910 ??
   / 2410 vs 2710/2910 ?? #1
Anonymous Poster
Epic Contributor
Is the turning radius shorter on a 2410 ? The Kubota brochure I have shows the turning radius being the same for the 2410 & 2710/2910 even though the wheelbase is different.
I am interested in the 60" Mid Mount Mower for weekly mowing and thought the 2410 would be more maneuverable. However, the 2710/2910 appears to be better suited for running a 5' brush hog, and I could move up to a 72" MMM instead.
2710/2910 owners: Are you satisfied with the MMM & the turning radius ? Do you recommed a 60" or 72" deck ?
Thanks in advance! I am moving up from a JD318 garden tractor for brush hogging and light FEL work.
   / 2410 vs 2710/2910 ?? #2
Some of the stuff in these tractor brochures is suspect--that is one of them. Increasing the wheelbase nearly 6 inches will affect the turn radius and considerably I think. I did ride a 2910 around when I got the 2410 just in case! It was only about 5 minutes on it but it did take more room to turn--they had a dirt lot--parking lot and I spun the tractors around in it going this way and that. I followed the 2410 tracks with the 2910 and when I got to the spot I had made a full left turn with the 2410 I did the same with the 2910--predictably I was well outside the turn of the 2410 looking at the tire tracks in the ground. Not scientific but a darn good indication. I think, however, that with the 72 inch MMM the uncut circle may not be much more than that of the 2410 with the 60MMM. My opinion, if you want a tractor that large then go ahead and get the 2910 but do not get the MMM. Take the 3,000 dollars (?) over to Lowes and get your self a Cub Cadet mower and a new push mower for the same price. Use those for the lawn area and your brush cutter for the rest--is this practical? Just a thought. J
   / 2410 vs 2710/2910 ?? #3
I don't have a brush hog (one spindle mower). But my B2400 easily handles our 6 ft 3 spindle finish mower.
   / 2410 vs 2710/2910 ?? #4
I have a 2710 with the 60 inch mmm. I am extremely happy with my choice, and mowing was the top consideration, including weight (ruts and shredding of the lawn). I was concerned about going up in size from the 2410, but that proved to be unfounded. With R4s I have not had any problems with lawn destruction, provided I am careful and not in 4wd during full lock turns. WRT to the 60 inch deck, I was concerned about maneuverability. After I purchased, I figured out that the 72 inch deck will actually decrease your effective mowing radius while mowing in tight spots, since it sticks out further toward the center of the turning circle. Also, I have heard that the 72 inch is considerably easier to put on and take off - you just drive over it. If I had it to do over again, I would opt for the 72 MMM with the 2710 (2910 would be nice, but not worth the extra $$s for the few ponies and adjustable 3ph). Do NOT be afraid of the maneuverability of the 27/2910 frame size over anything smaller - I had a JD LX172 that, while it could turn tighter, I had to tug the wheel, so it couldn't turn faster. Going into a tight turn, I would have to clutch down my speed, turn, then speed up, resulting in overall slower turn times. In my opinion, turning response time is more important than turning radius (within reason). Also, keep in mind that I am not mowing a suburban lot, even though I am mowing around my house. I have 4 acres of lawn, peppered with trees, shrubs, deck posts, swingsets, well heads, and houses, so maneuverability over several hours of mowing time 1-2 times a week was a big consideration.
   / 2410 vs 2710/2910 ?? #5
Farmboyron,
Hopefully you are also aware of the optional Bi-Speed turn option available only on the B2410. It was previously available on several other discontinued models including the B2150 and the B1700/B2100/B2400 series.
The 4wd Bi-Speed turn system forces the front wheels to turn faster than the rear wheels, with the net effect being a tighter turn with no turf damage.
To me, the ideal situation is to have two tractors; one with a rear finish mower and one with a mid-mower. I have two older tractors with that configuration. They each have their advantages as has been discussed many times on this board; if had to limit myself to just one type of mower, I would probably go with the 3-point hitch style because it is easier to get on and off when not in use. The mid-mower is more maneuverable.
Regardless of whether you go with a mid-mower or rear mower, if your lot has uneven spots that could cause a mower deck to gouge in then the 60' would be better than the 72"; otherwise, I'd recommend the 72".
Kelvin
   / 2410 vs 2710/2910 ?? #6
I'm looking hard at the 2910, now. One main thing that swayed me to Kubota is the weight is lighter than JD or NH for that size (for me this is good). I like the 2910 out of these three because of the nominal price difference, the seat. adjustable hitch arms, and extra power for hogging...
But I'm still researching.
I also ruled out the JD 4x10 series due to size & especially weight (~3000lbs vs. 1500-1800lbs). If I were primarily plowing/pushing/pulling, then the added weight would be important. However, for mowing over the 60x30 septic field that was just put in for $8K, I hesitate getting a heavier machine when I don't really need it.
As for the new 24HP version of the JD 4100, the 4115, the cost increase over the B2410/JD4110 isn't justified as far as I can tell. Also, the 4115 & 4110 have the FEL control lever mounted near the front right side of the seat, which I disliked because is got in the way when getting on/off the tractor on that side.
I have borrowed a 2710 with a 5' rotary cutter for the past few years in my field, and was very satisfied with its performance. As was stated in a prior posting, the 2910 with couple more HP at the PTO might allow me to slow down less often in the thick areas, but saving time is not that critical with just 3 acres to tackle. As for a 2410, I would not consider anything larger than a 4' rotary cutter for my field given my experience with the 2710.
   / 2410 vs 2710/2910 ?? #8
Farmboyron,I have a B2710 with the 72"MMM and love it. I can put on, or take of the deck in under 3min. on blacktop or on the shop floor. I mow 5 acres of yard at home and would not want anything smaller than the 72" deck. I use a 5ft. rotory mower at my shop to cut 3 acres with no problems. I would get the larger tractor, if you have alot to cut.
Are the 60" & 72" MMM decks "suspended" on the 2710/2910 (similar to a BX) -or- do the decks "ride" on the casters like the 60" MMM on the 7500 & 2410 ?
   / 2410 vs 2710/2910 ?? #10
They are exactly the same as the ones for the 2410 and 7500 in that they are ground contact type. To my knowledge the only Kubota with a suspended deck is the BX, excluding their GT, LT and ZTR stuff. There is more to it than just the decks, the BX has a height control knob for the deck below the seat and it is graduated in 0.5 inch increments and it has a lock position that locks the mower deck up so the 3-point can be used. On the remaining larger Kubotas there is no means for adjusting cut height except with the wheels on the deck which support fully the weight of the MMM. The wheels on the BX suspended deck are anti scalping rollers only and are intended to glide along--on smooth ground--approx 0.5 inches above the ground thus the weight of the suspended deck is--suspended--as in that it is fully carried by the tractors much larger wheels. There is no height control knob, there is no lock up control except you can insert a variety of pins in difficult places to lock the deck in the up position, also the BX I think has more ground clearence with it's deck up and locked than my 2410 --just eyeballing it sorta--there is not a lot of difference. A suspended deck and a tractor designed from the get go to fully integrate the advantages of a suspended deck is a superior mowing machine. There is a suspended 54 inch deck but alas the tractors are not designed to fully utilize it's advantages like the BX and 54 is to small anyway.
J
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
2006 Chrysler Town and Country Van (A51694)
2006 Chrysler Town...
205113 (A52706)
205113 (A52706)
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
