Tiller 240d Buying a tiller..
   / 240d Buying a tiller.. #2
tractordata.com
Yanmar YM240
1977 - 1981
Compact Utility tractor
Manufacturer: Yanmar
Factory: Japan
Original price (USD)
$6,000 (1981 )
Variants:
YM240: 2WD
YM240D: 4WD
Yanmar YM240 Engine:
Yanmar 1.1L 2-cyl diesel
full engine details ...
Capacity:
Fuel: 5.8 gal [22.0 L]
3-Point Hitch:
Rear Type: I
Power Take-off (PTO):
Rear PTO: transmission
Clutch: overrunning
Rear RPM: 540/1000
Engine RPM: 540@2200
Front PTO: optional
Dimensions & Tires:
Wheelbase: 58.7 inches [149 cm]
Weight: 1696 lbs [769 kg]
Front tire: 4.00-15
Rear tire: 9.5-24
full dimensions and tires ...
Yanmar YM240 Power:
Engine: 24 hp [17.9 kW]
Drawbar (claimed): 16.5 hp [12.3 kW]
PTO (claimed): 19.756 hp [14.7 kW]
Drawbar (tested): 16.54 hp [12.3 kW]
PTO (tested): 19.76 hp [14.7 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: manual
Brakes: mechanical internal expansion
Cab: Open operator station.
Electrical:
Ground: negative
Charging system: generator
Battery:
Number: 1
Volts: 12
LINKS TO BUCKEYE TRACTOR (2): Buckeye Tractor Online Catalog Page 03-01 Bed Shapers
"Garden Series" IMPLEMENTS: Buckeye Tractor Online Catalog - Garden Series Page 01
VIDEO: buckeye tractor company - YouTube
   / 240d Buying a tiller.. #3
I'm running a 5-footer (built by Sicma) on my Kubota B7800. B7800 is 30hp and 23hp at PTO. Soil type make a HUGE difference. I've got heavy soil (though the garden area is lighter).
I'd figure 48" tiller for the 240d would be about right: if this were a 4wd one "might" be able to go just a bit wider. Tractor's width is spec'd at 48.8", so would need to have a bit of an offset on any 48" tiller in order to completely cover a track.
   / 240d Buying a tiller.. #4
   / 240d Buying a tiller.. #5
I have the 5' version of this- great tiller.
48 Inch Rotary Tiller-Tillovators
   / 240d Buying a tiller.. #6
Check out these folks.Several advertisers here. They build their tillers like tanks. Home With tillers weight is your friend to have them work properly. Also forget the power requirements. I am running a YJR 074 with no issues and I am running it with a Bobcat CT 235 (26.5 hp PTO). I got mine used through an agg rental place. Look around.
   / 240d Buying a tiller.. #7
I have a 2 wheel drive YM2000 which is the grey market version of your YM240. I use a 5' King Kutter TG-60 tiller on it. At 630 lbs it is just about all the tractor will lift without front weights. I used it to till up a new food plot in soil that had not been tilled before. The soil is very sandy and it seemed like I was using about all the power the tractor had but never more. For my soil it was the perfect size. If you are trying to till new ground that is heavy soil I think 5' would be too much. Previously worked heavy soil would probably be ok. I've only had the tiller one year but so far I am happy with it. Its heavy weight kept it from bouncing around too much and it survived a few hits with rocks.
Thank you everyone, my mower is selling so I should be able to make a decision here soon. I see a maschio 36 inch... Used... Weighs a lot though. Isn't that like a Porsche of tillers? Will weight be an issue?
In thinking 48inch or smaller, I don't mind the extra time spent... The woods mower I have weighs 500+ lt has 4 wheels though... I need AG tires too. Such a bunch of expenses all at once. I won't be able to move much with a 500# tiller 6 inch deep in rather sandy but unbroken soil with my turf tires.
   / 240d Buying a tiller.. #10
Turf tires/traction should not be an issue with forward operating roto-tiller tines, which push the tractor forward.
NEW Ripper Shank (A53002)
NEW Ripper Shank...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
Toro Workman Utility Cart (A51694)
Toro Workman...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 42-6FGCU25...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
