2400H fronts
/ 2400H fronts #1
dinoedwards
kubota
23x8.5-12 are getting worn mostly from past owner, found 2 brand new in white. Seem to be both right side wheels? Does this matter or should I remove tire and turn it around?
Guy is asking 200 for both.
1st photo show treads going same way on both showing inside of rims.
????, I think this price is right! But should I change the one or not? The tag on mine does show "L" and "R" on label on each.
/ 2400H fronts #2
You will get better traction going forward with the tread pointing the “normal” way.
I have seen people put the front tires on backwards for loader work in softer ground since this provides better traction backing with a load in the bucket.
Normally both tires face same direction but running one each way won’t hurt nothing but the looks.
/ 2400H fronts
Just thought, What if I put them on backwards would it widen the stance in front?
/ 2400H fronts #4
Yes you can change the rims to be either narrow or wide stance. If you a mid mount mower the tires might hit the deck in the wider stance though.
/ 2400H fronts
Just got these brand new wheels and tires, guy said he had 2 sets and thinks they were lefts and rights now that I pointed out to him, so he sold the other set as 2 lefts,,,daaaaaa! I'm thinking, since I have 2 rights, put left on backwards and right on regular just for proper direction? Will that hurt anything? I do not have mower deck. Is it bad to have a little wider on one side and not the other?
I guess, is it that important for them to be directional I would like a wider stance.
/ 2400H fronts
Just put new fronts on, sits great and did directional so one is inside out, no difference is width I can see.
/ 2400H fronts #7
I have R1 ag tires so rims are different than R4. Can you measure the offset difference on those rims? On my R1 there is a significant dish or difference in offset.
/ 2400H fronts
Either will fit, like R4 little wider tire but yes need R4 rims too can't use R1 wheels with R4 tires vise versa
/ 2400H fronts #9
How is the little Branson treating you? I hope you're enjoying your time in the seat.
