2400H filter check
/ 2400H filter check #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Neighbor called and asked if I could feed his horses and plow his drive since he was snowed in and his kids place down south. - 6 today so I plugged her in for a couple of hours and it started right up. Left it sit and idle for about 8 minutes while I put on the insulated coveralls, etc. Drove it at 1500 RPM around my yard pushing a couple of drifts back and then over to neighbors drive which is about 300 ft down the road. Plowed some in his yard and then decided to increase the RPM's to around 1800 - 1900 for some heavier pushes. Made one push and started backing away and saw the tell tale brown streak in the snow. Idled it down and jumped off looking for the leak. Saw oil squirting out from the seal on the HST filter. Shut it down and walked home. Got the filter wrench, funnel and left over 5-gallon bucket of oil. Walked back to the tractor and removed the filter, it was only finger tight... inspected the O-ring for damage and reinstalled the O-ring in its groove an tightened the filter down. Filled it up with oil and started the engine, no leaks so I slowly increased the RPM's to 1500. Still no leak so finished pushing snow and drove it home.:thumbsup:
I suspect the cold oil increased the pressure in the filter causing it to leak. I changed oil and this filter at around 55 hours and currently have 118 hrs on the clock. I would suggest that you double check the tightness of this filter on your machines since I know this was tight when I installed it. This filter is on the left side of the tractor.
NOTE: At -6 Mobil 424 is kind of thick like syrup from the fridge
/ 2400H filter check #2
Was it Branson filter or after market?
Some have had problems with after market filters.
It was a Branson filter. Suspect the heating and cooling cycles from use in the summer caused it to loosen up. It looks like this filter uses an O-ring and requires the filter head to seal metal to metal with filter mount. I believe this design allows for the higher pressure use for charge pumps Vs the square seal used on most spin-on car engine filters.
/ 2400H filter check #4
Good morning oldnslo, you have owned your 2400h for some time now I also own one 2018,have you had good service with it , mine has 66 hours on it and has been awsome little work horse . I dont SEE many posts by 2400h owners . Hope this is agood sign their not having any problems with them. Is their anything I should watch for ? Thanks, Dan
