240 stuck in gear
   / 240 stuck in gear #1
jasontomitz
Hi all,
I read here a bunch, but haven't had to post much. My name is Jason. I am in Gainesboro, TN, after being in South Florida since '79 so I am a newbie :)
I bought and 240 Diesel a couple months ago. Today while bush bogging the tractor got stuck in 3rd gear. I can go from high to low range. The clutch stops the tractor but I can not get it out of gear.
Thank you in advance for any help...but I was hoping someone could give me a few ideas before I go back. There seems to be alot of knowledge around here :)
Jason
staticmap
   / 240 stuck in gear #2
I'm not sure about your model, but that was fairly common with the older 35's. The problem was a pin under the rubber cup at the bottom of the shifter; there's a post on here somewhere that details how to remove the cover next to the shifter and take a large screwdriver to pop it out of gear. Hopefully it will work the same way for you. Best of luck
   / 240 stuck in gear
Thank you, I will see if I can find that post.
   / 240 stuck in gear
That was the problem. Thank you again! I love this forum :)
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2011 GMC Sierra Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
Rhino FL15 (A50121)
Rhino FL15 (A50121)
