23HP B&S Head Gasket Problems?
/ 23HP B&S Head Gasket Problems? #1
MBDiagMan
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I bought a Z-Force 48 last Fall. I love it, but it is using quite a lot of oil. I called my dealer this morning and described my situation.
They told me that they have had a head gasket problem with some of these engines allowing oil to seep through into the combustion chamber. I will take it in and leave it with them.
Has anyone experienced this?
Thanks for your replies,
Doc
/ 23HP B&S Head Gasket Problems? #2
Oh yeah, those motors always gave those kind of problems, thats why the '05 units have Kohlers.
Gamble,
Are they able to repair it properly so that the problem won't reoccur?
Thanks very much for your feedback,
Doc
/ 23HP B&S Head Gasket Problems? #4
I'm thinking like gamble77, at least I think he's thinking like I am. By the way I don't think very often, and when I do think, I'm wrong /forums/images/graemlins/confused.gifmost of the time. But anyway in my opinion I think that the Kohler is the better of the two engines. JUST MY OPINION!!
/ 23HP B&S Head Gasket Problems? #5
They can repair it, but to my knowledge there is no "update" kit for the motors. We just seal them up REAL good so they won't leak anymore.
/ 23HP B&S Head Gasket Problems? #6
If B&S doesn't have a new and improved head gasket [or another solution]; which I'd say they owe you anyway [well under warranty yet isn't it?] there are other options:
There's a very high temp/high pressure gasket material [like the Permatex silicone, but I think a different brand], that you can apply right around your oil ports on each side before installing the gasket. I know at least one tractor dealership uses it in similar situations. The downsides are:
1. I can't think of the proper product [I have been very happy with silicone on a certain intake manifold]
2. You need to be careful not to get globs that could go roque and contaminate your oil.
Also, some head gaskets respond well [others negatatively] to about 25%-50% additional torque - to a new one not the exisiting. The negative here is that you'll say many curses, then need to beg, borrow, or steel a heli-coil set if you strip the threads.
I really don't think you should have to regret having the B&S; but they deffinitley owe you a solution without too much BS. /forums/images/graemlins/crazy.gif
/ 23HP B&S Head Gasket Problems? #7
Could go "old school" and try painting the head gasket with aluminum paint on each side, assemble almost dry. Never tried it myself though. Also, even if it doesn't quite make temp, you could try the hi-temp silicone.
Looks like at least Gamble's dealership already uses some of the "old mechanics" fixes; maybe your dealer will has a good solution too. /forums/images/graemlins/smile.gif
Thanks for all the responses.
I will take it to the dealer and give them a shot at it. If it breaks again after warranty I will seal it up somehow. Although I'm not a small engine guy, I am an ASE Master so I think I can come up with something that will work if I end up ultimately having to do it myself.
It's just disappointing to have to worry with this. it is 50 miles to my dealer and I don't know how good they are with such issues.
Except for this problem I love this engine. It's quiet, smooth and powerful and for it's size it's pretty stingy on fuel.
I'll keep you all posted. I guess I'll be mowing on my old 2145 for awhile.
Thanks again,
Doc
/ 23HP B&S Head Gasket Problems? #9
Could it possibly the maching on the head and block being the cause for the head gasket failure or perhaps improper torquing warping the head?
Egon
Well, this is the outcome from the dealer trip. I hauled it over there last Friday and left it. When I called back they said that the problem was a "crudded up" crankcase breather.
This is disappointing. Either this is really not the problem with it using so much oil or if it is how did it get plugged up?
The unit only has 12.1 hours on it. I changed the oil and filter at 5 hours or so. Will I have to replace this crankcase breather every 10 hours or less?
They also said that I could not service this part, that it is dealer service only. In a pigs eye. If they can change it, I can figure out how to change it, but I would like a hint about where to look for it.
I talked to them about trading for an M48K. They have one in stock, but wanted to give me less than half what I paid for my mower against list price of the M48.
It wasn't a good day, but if I'm lucky, crankcase breather was indeed the problem and a fluke. If it was indeed the problem it's hard to imagine how it won't get "crudded up" again soon.
Thanks for any feedback about the crankcase breather or the Intek oil usage situation in general.
Thanks again,
Doc
Well folks, I guess you could say that I'm a little aggravated at this point. This thing is still using oil. It's 50 miles to my dealer one way. They are not exactly long on personality which I can deal with if they will deal well with their customers.
I gave them a chance to make it good by seeing how they would trade for a commercial and they offered me less than half in trade and that was against full list price.
If they had fixed it when I gave them the opportunity it would be a non issue at this point. I'm pretty fed up with them and it's time to get a commercial mower that will hold up. I have been pretty loyal to CC for many years, but I guess that this is where we part ways.
I really don't have all that much problem with CC, it's the dealer that is losing a customer for CC. Not an uncommon tale I'm sure.
Anyway I appreciate the help and have enjoyed the discussions on this forum.
Best of luck to all,
Doc
2023 General XP 1000 Sport (A62679)
2023 General XP...
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
2007 PETERBILT 379 6X4 TRI/AXLE DAY CAB TRUCK TRACTOR (A59914)
2007 PETERBILT 379...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
