23C Injection Pump Mounting Gasket
   / 23C Injection Pump Mounting Gasket #1
pojawis
I'm installing a new Lucas/CAV injection pump on a Ferguson TO35 Standard 23C diesel and found that a mounting gasket was not included. Can a mounting gasket be made from paper gasket material or any of the form-a-gasket products?
Thanks for any reply.
   / 23C Injection Pump Mounting Gasket #2
Home made paper gasket would be far better than any liquid, since you might just want to loosen and rotate the pump a bit at some time in the future. Hard to do if it's stuck tight with some sort of goop which will undoubtedly leak if disturbed.
   / 23C Injection Pump Mounting Gasket #3
I recently used rubber gasket material to cut my own gasket when I worked on my injection pump (checked to ensure it was safe for use with fuel/diesel). Bought it in a small roll at a local auto parts store. I think they all carry it. Was simple and worked perfectly.
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
