23C Injection Pump Mounting Gasket
   / 23C Injection Pump Mounting Gasket #1
pojawis
I'm installing a new Lucas/CAV injection pump on a Ferguson TO35 Standard 23C diesel and found that a mounting gasket was not included. Can a mounting gasket be made from paper gasket material or any of the form-a-gasket products?
Thanks for any reply.
   / 23C Injection Pump Mounting Gasket #2
Home made paper gasket would be far better than any liquid, since you might just want to loosen and rotate the pump a bit at some time in the future. Hard to do if it's stuck tight with some sort of goop which will undoubtedly leak if disturbed.
   / 23C Injection Pump Mounting Gasket #3
I recently used rubber gasket material to cut my own gasket when I worked on my injection pump (checked to ensure it was safe for use with fuel/diesel). Bought it in a small roll at a local auto parts store. I think they all carry it. Was simple and worked perfectly.
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
2019 DODGE RAM 5500 HD SERVICE TRUCK (A51247)
2019 DODGE RAM...
(INOP) EZGO ELECTRIC GOLFCART (A51248)
(INOP) EZGO...
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
