2365 hoe
   / 2365 hoe #12
Drew, it sounds like he has the optional remote valve levers with the four ports in the back instead of the type you show which is what I have also. I added mine myself when I got the bh. I've never seen the lever set up on a tractor to have any idea where they get the hydro pressure from. As far as which way to turn our type of valve, counterclockwise until it stops for the bh and clockwise until it seats for the 3pt. Maybe he has a problem with the control valve for the curl. One easy test would be to switch four lines from the control blocks under the hand controls. Curl and crowd would be the easiest way to go. Just remember the joystick will be different. If the curl still squeals, then it's not the control valve but something further down the line to the cylinder. Just a way to test and should take about 1/2 hour.
After going back, I see he has a CK20. I have no idea about those tractor controls but the BH test would still work. My KB2375 shouldn't be that much different.
   / 2365 hoe #13
Dave,
This lever your talking about, is it right next to your 3PH lever? If so, it's for the rear remotes which are used to power the BH. As for the squealing, if is it coming from the hydraulics when using that function (curl/uncurl), does the bucket move any slower than it use too? Do you still seem to have the power to curl the bucket when trying to dig?
Steve
   / 2365 hoe #14
Sorry, I made an incorrect statement about which way to turn the valve. I put my BH on today and clockwise is for the BH and counterclockwise is for normal. This is for the picture that Drew is showing on the CK30hst.
   / 2365 hoe
Steve, the hoe seems to have plenty of power. The curl and uncurl is a little slow. Dave
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
Deere 35P (A53317)
Deere 35P (A53317)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
