Backhoe 2365 backhoe squeals like a pig
   / 2365 backhoe squeals like a pig #1
cptdave
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
When I uncurl the bucket it makes a loud squeal. The dealer has replaced the cylinder. Any suggestions?
   / 2365 backhoe squeals like a pig #2
Air in the cylinder? Try cycleing it several times to work all the air out. I know when I rebuilt my loader bucket cylinders, it took alot cycleing of the bucket before it stopped. If that's not it, maybe you've got a "frozen" or sticking bucket pin. Check all pins and be sure they're taking grease.
   / 2365 backhoe squeals like a pig #3
don't want to state the obvious..... is your fluid level full? low oil will result in air in the system and make noise.
Thanks ,I will check both possibilities.
Dave
   / 2365 backhoe squeals like a pig #5
A bent rod will squeal pretty bad when it goes in or out of the cylinder.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
2003 Big Tex 10PI...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
