Backhoe 2365 backhoe squeals like a pig
/ 2365 backhoe squeals like a pig #1
cptdave
Bronze Member
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
When I uncurl the bucket it makes a loud squeal. The dealer has replaced the cylinder. Any suggestions?
/ 2365 backhoe squeals like a pig #2
Air in the cylinder? Try cycleing it several times to work all the air out. I know when I rebuilt my loader bucket cylinders, it took alot cycleing of the bucket before it stopped. If that's not it, maybe you've got a "frozen" or sticking bucket pin. Check all pins and be sure they're taking grease.
/ 2365 backhoe squeals like a pig #3
don't want to state the obvious..... is your fluid level full? low oil will result in air in the system and make noise.
Thanks ,I will check both possibilities.
Dave
/ 2365 backhoe squeals like a pig #5
A bent rod will squeal pretty bad when it goes in or out of the cylinder.
