2355 MFWD doesn't roll
/ 2355 MFWD doesn't roll #11
Red Loctite does have a lot of strength, but I don't know if I would be comfortable using it to retain a bolt that doesn't get torqued very tight to start with and is subject to some considerable stress. I would try to find out what is wrong causing the extra clearance in the stub axle. Maybe an incorrect part was installed from factory if it has never been apart. Can you post some pictures of the final drive, stub axle, and diff lock parts? How much clearance is there to allow the retainer to fall off?
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2016 JLG 1932ES ELECTRIC SCISSOR LIFT (A59823)
2016 JLG 1932ES...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
