2355 bad steering leak, need help.
/ 2355 bad steering leak, need help. #1
dusty3030
Veteran Member
West TN
Kubota MX5400 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
My 2355 started blowing oil out of the front seal on the right hand steering cylinder when I turn right. Figured bad seals so I ordered the kit and replaced all the seals in the cylinder. Put it back together, same thing. I can't find a restriction in any of the lines on the two front cylinders, need to start working my way back. Right now I'm lost, any help appreciated.
/ 2355 bad steering leak, need help. #2
It sounds like the rod is bent, scored has a knick in it ect. Something has to be out of wack for it to leak oil. How's the barrel look? The piston?
