234 Water pump and belt failure
   / 234 Water pump and belt failure
Just looked a few minutes ago. I think you are going to have a difficult time splitting the PTO shaft from the crank pulley without taking everything apart. I forgot, the bolts that hold the shaft on there go completely through the crank pulley/rubber isolator. You have to get to the back of the bolts to hold them from spinning when removing them. I think you will agree that it is a crazy setup...lol. Good luck my friend. Feel free to ask more questions.
   / 234 Water pump and belt failure #12
Hey Warment: Thanks for all your help . . . I am starting to put together a page of diagrams that show PTO, Radiator etc. I bouught a Dayco belt with cogs at top in lieu of Gates with cogs on bottom. . . I think the Gates is a better belt and more like original. As you say this is such a stewpid setup to change belt, I am tempted to put 2 belts on - 1 working and one spare tied off if possible.
Do you think I should go with Dayco or order the Gates. . . Going to search out Kevlar replacement as well. I have so many other projects on the go I surely didn't need this and stressing me out. Hopefully it is not as big a deal as I envision.
Thunderstorms here. . . You have a fine day.
Frank Read - - - Canning Ontario ( Birthplace of Canada's #1 Hockey Dad - father to the Great One #99 )
Frank,
I just looked back at my online records...
I purchased and installed the following: CASE IH 676622R1 Replacement Belt | eBay
Seems to be working just fine.
I don't think you will have any difficult issues...just a lot of items to take off and put back.
Also, shoot me your email if you want the pdf for the 234 engine. Not sure where I got it from. It's slightly difficult to use, but has diagrams and part numbers. Of course, the pto and deck are not shown.
3PT HYD HAY FORK (A52708)
3PT HYD HAY FORK...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2022 Kubota Z422-54 Zero Turn Mower (A56436)
2022 Kubota...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58216)
2008 TCE...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
