2320 w/loader length?
/ 2320 w/loader length? #1
Staghead
Rochester, Mn
What is the length of the 2320 w/loader attached? Also what does your average BB or tiller add to that w/Imatch?
How much does the loader weigh?
Basically I'm looking to see what kind of trialer I'll need to pull this type of set up around. Thanks.
/ 2320 w/loader length? #2
Hey Staghead.... My 2520 measures approx 12'2" from tip of the bucket to my i-Match.... add about 3' for my bb and you're looking at 15'2".
I don't have the exact weight on the loader at this time... but believe it's approx 650ish (200cx). Hope that helps a little...
That certainly does help.
Thank for the quick info!
Anyone have trailering recommendations for this set up?
/ 2320 w/loader length? #4
I had looked at this for my 2520. The 2520 is about 2000lbs, I figured 1000lbs for accessories was a little light - especially if I fill the tires ever - so I decided that 4000lbs usable weight was what I wanted. The Bri-Mar T-512 (Bri-Mar Dump Trailers) is pretty close, but I thought it was a little tight at 3750lbs useful loading with loader/backhoe/filled tires/etc. Besides, it's not quite long enough for the 2520 with a rear attachment. Any bigger than that and the tractor/trailer combo would exceed my truck's 5000lb limit (call me paranoid) so I decided to wait until I can get a real towing machine with better than a class 3 hitch. Luckily I haven't needed to tow the 2520 anywhere.
You can also explore a bit on Hecht - they're a local NJ company but it could give you links to other manufacturers.
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
More info coming soon (A61574)
More info coming...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
Utility Cart (A59231)
1991 WEL and 1980 TL FLOA (A61574)
1991 WEL and 1980...
