2320 tractor mower won't raise and lower
   / 2320 tractor mower won't raise and lower #1
Margareta
Kansas City, mo
John deere 2320
I hooked up a loader to move something and then unhooked it but now the mower, itself, will not raise and lower. It is resting on the wheels but won't move up and down. Any ideas about what I forgot to do?
   / 2320 tractor mower won't raise and lower #2
Do you have independent lift or the three point lift. If you have the independent lift, make sure you are hooked to the right quick connect. If so, hook and unhook the connection to see if it was properly attached. I've never done it myself, but my son somehow managed to hook up the connector so it looked like it was connected but actually was not fully engaged.
   / 2320 tractor mower won't raise and lower #3
If it is the 3 pt lift, make sure the valve under the seat is open. I had this problem right after I had my tractor delivered and it was the master lift cylinder was not sealing and so once it was down it would not raise up again. See if the 3 pt drawbars are raising. I could get mine to raise after tractor was off for a few hours but would not lift after 1 or 2 operations.
That was it! Thank you very much.
Margareta
Thank you so much for your help. I didn't have the connectors hooked well.
Margareta
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
1779 (A51248)
1779 (A51248)
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
20pc 4ft. x 3ft. Yellow Metal Diamond Plate (A55758)
20pc 4ft. x 3ft...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
