2320 rubber joystick knob
   / 2320 rubber joystick knob #1
ScottK
Redmond, WA
JD 2320 w/200cx loader w/53" bucket
Anyone have trouble getting the rubber knob to stay on the loader joystick? I was thinking of gluing it on somehow but not sure what will work. It seems to come loose quite easily. I'm sure it's half my fault (stess manuevering on hills and such), but after all it is only a friction fit of rubber on metal. Is there a retrofit? I understand all the current Deere models are this way.
   / 2320 rubber joystick knob #2
I've had my 2320 since October and it now has almost 40 hours on it. I use the **** out of my FEL and I have not had a single problem with the joystick.
   / 2320 rubber joystick knob #3
I havent Had A problem With Mine either I have 14 hours on it ! Suggestion Get A spare knob For Joysick ! & use your old one I would Black Rtv Gasket sealer or 100% clear silicone Dap Like for windows & gutters & doors That stuff has A 50 year warranty Put some Silicone on it & lrt it cure 24 hours & you Will be set ! Take care
   / 2320 rubber joystick knob #5
After about 110 hours of operation, the knob on mine is OK also.
   / 2320 rubber joystick knob #6
The best adhesive I have ever seen for knobs is 3M Super Weather Strip Adhesive. I have used it on a lot of knobs over the years. It comes in yellow and black.
   / 2320 rubber joystick knob #7
Scott,
Same problem. I figured I was lucky just to find it after losing it moving snow.
Right now I've got it back on with just a friction fit. Figured I'd use some silicone once the weather got better. I like some of these ideas better. Thanks for the tips guys.
Joe
   / 2320 rubber joystick knob #8
You can try what they use for golf club grips.
wrap the stick with 2-sided tape, peel the backing off, soak it down with lighter fluid, then slide the knob on.
24 hours later, the fluid will have flashed off and you'll have to cut the knob off in pieces to get it off again.
oh, and wash the drips of lighter fluid off your tractor before starting it up again.
;) :eek:
JCB said:
Scott,
Spirit scooter (A55787)
Spirit scooter...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
UNUSED FUTURE EXCAVATOR ATTACHMENT SET (A54757)
UNUSED FUTURE...
2016 John Deere 326E (A47477)
2016 John Deere...
