2320 Kubota
/ 2320 Kubota #1
NUTTERDW
I have a 2320 Kubota 4 wheel drive lawn tractor I bought in 2014. Recently the Hydrastatic foot pedal has started not returning to the neutral position. I have checked for trash around the levers and greased the hinge joint but to no avail. The pedal has to be in the neutral position or it won't allow the starter to engage. I have to use my hand to rock the the foot pedal back and forth to find the neutral position. It is not the switch because the tractor creeps in what ever position the pedal is stuck in. I also have an older B 1550 that does the same thing. My Kubota dealer is 60 miles away. Any one have any suggestions.
/ 2320 Kubota #2
I had the same issue on mine. There is a damper/piston contraption that the linkage is connected to. I think it's function is to ease the jolt when you change directions on the foot pedal. In my case the damper was stronger than the spring so the pedal could not re-center on it's own. When I priced the replacement part it was well over $100. I removed the part instead. It works fine although I need to be careful when changing directions. If I take my foot off the pedal too quickly it is quite a jolt and is probably as hard on the machine as it is on my back.
/ 2320 Kubota
Thanks for the information.
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
Unused 2023 Hustler LX890 235 Gallon Sprayer Tractor Attachment (A66734)
Unused 2023...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
CAT 330DL Excavator Grapple (A68134)
CAT 330DL...
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
