Tires 2320 Front Tires Rubbing CX200 FEL Stand Bar
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #11
If you've had the bad luck to have bent the stand and need to replace it, it's JD p/n AW33086 STAND and it lists for around $230
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #12
OR you could chain it to weight hangar and use hydraulics to bend it back up after you release latches - farm style!!:D
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #13
farm style!!:D
Yes that is the way we would do it on our farm!!:eek::eek:
Thanks for all the help guys! I played with the FEL this weekend and I think everything is OK now that have taken it off and on again. This is small rub when I do an extreme turn, but from the look of the paint that has been rubbed off this has probably been going on since I got the machine.
I don't have any front quick-hitch attachments on right now. The stand tube does not appear to have been bent either. I don't see any signs of stress on the paint (I would imagine it would flake if I bent it)
The machine "feels" like it always has....so I would guess everything is OK now. (Crossing Fingers)
Thanks again!!
BILL
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #15
And that's it???:confused:
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #16
Nothing else? Post one to the last seems to be leaving a lot out.
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #17
Just so you know what the front bar on my tractor looks like here is a picture of it. I don't have any tire rubbing on it.
I am still trying to get my digital Camera, but mine doesn't look like yours Vsteel. Yours appears to "jut out" from your tractor at an angle, where mine is pretty much straight down. I talked with my deal last week and they said they will come and look at it because I am still getting the rub.
Once I get my camera back I will take pics and post.
Still don't have pictures yet, but the stand got much worse yesterday. I was moving a lot of dirt and rocks and noticed that I was rubbing the tires on the stand A LOT. After a couple of hours of moving dirt I looked down and saw that I burned a hole into the stand tube. Not good.
The dealer came by last night to drop off my manuals and I had him look at the stand bar. He said "Yup, that's bent". Like I said before, I still don't know how I bent it. Maybe I bent it taking it off, putting it on, or hitting rocks? But he said the bar shouldn't be pointing 90 degrees to the ground but more like 45% angled up.
I asked him what to do...and he said be careful not to let any more rocks hit it :). So I said I need to bend it up because it is rubbing my tires and going to kill the tires. He said to try to bend it back.
So I hooked a chain to it and hooked another end to a telephone poll on my property....and SLOWLY put the tractor into reverse. The key is to pull the bar out, and not up. Pulling up is not going to help...so that is why I choose the telephone pole as I could put the chain exactly where I needed.
This has helped alot as I now have about 4 inches of clearance from my tires and the bar (In full turns :) ) But what I don't like, is that when I am digging dirt, rocks from the piles in the yard it is VERY easy to hit the bar with a rock, etc. This bar is VERY easy to bend and before you know it, you have bent it by just touching a rock.
I guess I have to be VERY careful working around rocks now. I would have expected this bar / tube to have some protection if it so easy to bent. :(
Anyways, I at least know how to fix it if I bend it towards the tires again. Just hook up to telephone pole :) I wonder what will happen the next time I take the FEL off.....we'll have to see.
My experience as a new tractor owner continues.....
   / 2320 Front Tires Rubbing CX200 FEL Stand Bar #20
Sorry to hear of your troubles Bill. My only complaint with the FEL is the stand. To me, it seems to be lacking in strength for the weight that it has to support (the FEL). If it is any consolation, I don't think a new stand is too expensive, although we all have spent so much just to get the tractor! Good luck
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2013 Peterbilt 40 T Crane (A55973)
2013 Peterbilt 40...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
