2320 drivetrain/u joint woes
   / 2320 drivetrain/u joint woes #1
spelunkersorta
Illinois
John Deere 2320
I have a 2320 with 420 hours on it. It has been serviced regularly per the guidelines/reccomendations in the manual. I was experiencing a vibration that got worse when I throttled up. Upon referencing my manual I replaced the fuel filter and outer air element to fix "rough running". After replacing those two items the engine ran a little smoother, but the vibration was still there. I drove it aproximately 100 feet @ varying throttle positions and heard a loud clunk below me. The engine was still running and was incredibly smooth, but I had no hydraulics at all. I had no leaks, no front wheel assist, nothing would move. I pushed/pulled it into my yard, manually removed my loader (not easy) and pulled it over my mmm. After having a 15 minute in depth conversation with my dealer rep/technician they had no ideas, but would be glad to come get it and look at it, but it "didn't sound good." I called a farmer buddy of mine and after 2 minutes said "sounds like a drivetrain issue." Started poking around and sure enough front u joint = lunch. It has a zerk on it and I do remember servicing it, but will admit that it is in a bad spot and might not have received the attention that more accesible zerks did. Now to the questions, anyone experience similar issues? Anyone else think a u joint should last longer? Any recourse to challenging John Deere on this issue? I am thinking about taking it to a drive train specialty shop (have done a good job in the past for me) rather than pay John Deere prices for a *new* one. Should I have them put in greaseable zerks or the sealed ones. Are there any other concerns regarding my drivetrain? The splines look good coming out of motor and the transmission. Thanks for reading.
   / 2320 drivetrain/u joint woes #2
A broken front u joint should not cripple your hydraulics. Seems more is wrong that just that by the way you explain it.
   / 2320 drivetrain/u joint woes #3
U-joints have been in use for decades, we've all replaced them on some car we've had... I don't see anything different with the tractor flavor (other than heavy duty) so the drive train shop should be able to do a credible job. But I suggest getting quotes from both the JD shop and the other guy for comparison. He may need to get the part from JD, and the labor/time costs may be quite similar. If that were the case I'd let JD do the work because they work tractors for a living.
Good luck...
   / 2320 drivetrain/u joint woes #4
there was a post on another tractor forum about some of the zerks on the 2320 drive line.. Bottom line from the dealer/mfg was that yes there were a few zerks on driveline that are very hard to get to, but they didnt need to be greased (sealed at the factory) because they were NOT running at an angle..
Brian
   / 2320 drivetrain/u joint woes #5
The front U-joint on my 2520 does not have a zerk. Since I run 4WD most of the time, I'll be interested to see how lond it lasts.
   / 2320 drivetrain/u joint woes #7
Hi I do not think you can just get the u-joint from john deere, looks like they sell you the the whole driveshaft. If that is the case I would try a driveline shop. And since your hyd. pump runs of the tranny it would kill all of the hydraulics. Good luck.
   / 2320 drivetrain/u joint woes #8
By front u-joint are you referring to the front wheels? Or the front u-joint from the engine to tranny?
   / 2320 drivetrain/u joint woes #9
My 2006 2320 blew the drive shaft. I left it in the road after plowing a neighbor. I took out the shaft for the blower too. No zerks on the drive shaft joints. The updated shaft I got from Deere was thicker about an inch compared to the original which was about 3/4" thick.
Your shaft may be bent, remember it turns regardless whether the tractor is in 2WD or 4WD but you must be moving for the shaft to turn.
Lift the front end and have someone turn one wheel while the other is held stationary, this will turn the shaft and you can look under the tractor to see if it's straight.
Hope this helps,
Rob
   / 2320 drivetrain/u joint woes #10
By the explanation in the first post,it would be the latter,and make perfect sense why nothing works.........no pump,no hydraulics.
Greg
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
WESSEX CRX 180 LOT IDENTIFIER 267 (A53084)
WESSEX CRX 180 LOT...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
