2320: Blew 2 Fuel Soleniods using Cruise Control
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #1
bill1369
Massachusetts
JD 2320
Hi All,
I have blown 2 Fuel Solenoids (the second one literally exploded). The first time this happened, I was using the cruise control on my 2320 (which is a lever you pull up....not an electronic switch like in 3320, etc). I was driving along for about 15 minutes and then big puff of black smoke from under the hood. I investigated and noticed the wires on the Fuel Solenoid were fried. I replaced Fuel Solenoid (and the 40 Amp fuse near the alternator as that blew as well) and was back in service. Couple of weeks after this, I was using the tractor and needed cruiser control. Was driving around in cruise control for about 10 minutes and the same exact thing happened to the Fuel Soleniod....this time it literally blew up....and I blew the 40 Amp fuse again
I must have an electrical problem SOMEWHERE that only gets triggered when I use the cruise control.....but looking at JDParts, it looks like it is all mechanical.
Anyone have any ideas?? I have looked and looked at the machine and don't see anything shorting out.
BTW: I am out of warranty. Tractor is 3.5 years old
Thanks,
Bill
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #2
I just had my dash apart on mine. Yes, it is all mechanical, but there are some wiring harnesses near the lever and linkage. Probably a good idea to check around that area.
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #3
I would check all your grounding cables for good contact to start with and look closely for any physical damage to the wiring.
2019 POLARIS RANGER XP1000 RTV (A51406)
2019 POLARIS...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2008 Caterpillar 262C Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
