2320 - add hydraulics for grapple?
   / 2320 - add hydraulics for grapple? #1
Tenn_Blue
N.E Tennessee
Deere 2320, Bobcat 322 mini-ex, Bobcat 763 skidsteer
Hi everyone - I am considering building a brush grapple for our JD 2320. It would be a light duty one, in keeping with the lift capability of the 200x loader. BUT, my tractor doesn't have front (or rear for that matter) hydraulic accessory lines for the grapple cylinder.
Wonder if there are any 2x20 owners out there that have had the hydraulics installed - either JD brand (if availible) or aftermarket, and if you are satisfied with them. Can I buy the parts and do it myself, of is it a dealer-only install? Ball-park, what should something like this cost me?
Also, for a grapple type attachment, could I use a diverter circuit, or would I be better to run a whole third line and control?
I've got the mechanical and hydraulic aspects of the grapple/bucket figured, but a little foggy on how to get the tractor side supply to it.
Thanks in advance!!!
   / 2320 - add hydraulics for grapple? #2
Yes it can and has been done:thumbsup:
For the JD machines, the "electric diverter" is the simplest way to get a front remote
Here are a few threads:
Added Remote to FEL... - TractorByNet.com
2520 - Diverter Valve Project - TractorByNet.com
Here are some on rear remotes:
Installing a 2 spool SCV on a JD 2320 - TractorByNet.com
2520 - Rear Remotes Added - TractorByNet.com
Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 - TractorByNet.com
Rear Remotes on a JD4110 - TractorByNet.com
A search of the term "diverter" both here and in the Hydraulics forum will turn up hours of reading also.
   / 2320 - add hydraulics for grapple? #3
You can save some money and do it yourself or go the easy route and have the dealer do it. I chose easy. They put a Fosse valve diverter on and ran the lines to the grapple. Not as complicated as I thought it would be. Cost for the valve, parts and labor was around $600-700, I think. Works great
   / 2320 - add hydraulics for grapple? #4
kennyd
Thanks for that summary. :)
Thanks for the info guys! I had looked before posting - guess I didn't look far enough back....
If I went the diverter route, which is the "accepted" circuit to tie into - Lift/lower or curl?
Can the diverter work while the circuit is in use, or do you have to let off the "tension" first? For example, if I put it on the bucket curl circuit, could I be curling the bucket, hit the button (without letting off the joystick) and it would switch over to the grapple, or would I have to let off the joystick before switching?
Sorry for all the questions. This is all new to me! 4 years ago, I had never SAT on a tractor, now I are an owner/operator :p
   / 2320 - add hydraulics for grapple? #6
If you searched the term "diverter" as I suggested, then you you would have that answer...it's place on the dump/curl circuit 99.9999% of the time-you never want to interrupt the lift/lower for safety reasons IMHO. Plus it's just more useful that way.
Yes, you could...but I wouldn't recommend it.
No worries...we where all new at one time. That is the reason I implore you to search-not just because I am lazy:laughing: There is so much info in the older threads.
2010 Ford E-450 Super Duty Transport Bus (A52377)
2010 Ford E-450...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2121 (A51244)
2121 (A51244)
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
