2320 50HR service stumper
   / 2320 50HR service stumper #21
Just did my 50 hour service on my 2520 at 52 hours. I used 4 qts of the 15w-40 JD oil and 4 gallons of Low Vis Hyguard. My hydro screen wasn't as bad as the one pictured in the previous post, but it definitely had significant metal shavings adhered to it.
The engine oil change was easy, no problems...just use 4 qts. Some manuals state 3 qts, which is incorrect.
The hydro change wasn't too bad. I couldn't get a 5 gallon bucket under the machine, so I used a 2 gallon oil catcher that I use to change oil in my car and just stopped the flow of oil midway through to dump it. The bolts on the screen cover on the back of the unit need a fairly long extension to get to as well.
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A55788)
2017 Freightliner...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2013 CATERPILLAR D5K2XL CRAWLER DOZER (A52705)
2013 CATERPILLAR...
2001 TOYOTA TACOMA SRS TRUCK (A54756)
2001 TOYOTA TACOMA...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
