2320/2520 rear hydraulics
/ 2320/2520 rear hydraulics #1
Rustyrat
Maine
JD 2305 tlb
This is probably a stupid question but I will ask it anyway. Does a 2320/2520 have hydraulic at the back of the tractor as standard equipment? If not, what option is it called and about how much does it cost? I am assuming that if I want to have a wood splitter or chipper that needs hydraulics, there needs to be a coupling of some sort at the back of the tractor.
/ 2320/2520 rear hydraulics #2
Short answer: No, they do not have rear hydraulics as standard equipment.
For power implements like logsplitters and backhoes that have their own valves you need to "Power Beyond" option. It is basically a set of hoses that have a constant supply of hydraulic oil whenever the tractor is running. The kit sell for about $250 and is fairly easy to install.
Adding valves to control cylinders is a little more complicated and expensive ($500 and up) and will require some custom fabrication because JD does not offer a good solution for this for the smaller tractors. There are quite a few threads I can link when your ready.
/ 2320/2520 rear hydraulics #3
Hey Kenny,
Deere finally came out with a rear SCV for the 2320, needs
the power beyond kit, but there is now an official kit from
JD.
LVB25927 is the part number, lists for $399, but does not
include the power beyond.
:D
/ 2320/2520 rear hydraulics #4
Hey Kenny,
JD.
:D
Thanks Dutch, I heard about one for the 2520, but not the 2320.
But, at $399 (for one valve/remote) plus the PB kit...He can add 2 or 3 valves with aftermarket pats for the same money.
/ 2320/2520 rear hydraulics #5
You're not running a chipper hydraulically either. I just went through seeing if that was possible.
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2012 TURNKEY INDUSTRIES 29DT DATA TRAILER (A67714)
2012 TURNKEY...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2011 Hyundai Sonata Sedan (A66738)
2011 Hyundai...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
