231S turns over but will not start just died while running
   / 231S turns over but will not start just died while running #1
MrBushhog
Elkmont, AL
MF 231S
231S 500hrs
the other saturday i was mowing with rotary cutter. after about 5 min the engine just stopped like i turned the key off. took several attempts to get it going and went on cutting. sunday tractor cranked right up and finished mowing parked it when done. monday tractor will not start, turns over fine. tractor is somewhat new to me as i am used to the regular 231. anyone have any tricks or obvious things i can try before i take to a shop? i feel that its a electrical issue.
   / 231S turns over but will not start just died while running #2
231S 500hrs
Electrical is a fare guess. Is there any loss of power/jittery operations/sputtering that precedes it? Any sort of clue that something's coming at all?
   / 231S turns over but will not start just died while running #3
Check for lose wires etc. on all the safety switches etc., etc...check the wire leading to the fuel shut off solenoid for shorts...look for chewed wires...
good luck...
no warning at all just died
good luck...
checked safety switches well the best i could since i had no tools, i feel you are on the right path on the fuel shut off solenoid. any tips or places to find more info about it.
update.... thanks for helping
got tractor to run by a hot wire to solenoid but thats the only way. has two wires going to the solenoid, a red wire and black wire, on one if them has 12 volts with key in run position and start position. still will not run with the connector pluged in. going to try and trace down the wires tomorrow.
appears to be the fuse block/fuse connection. new one is $125, i am going to make a new one with blade typr fuse.
got a new blade type 6 circuit block from waytek. $6.00 for block, $5.00 cause of "small order", $15.00 for shipping.
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
