2310 suddenly loses power and engine almost stalls when mowing
   / 2310 suddenly loses power and engine almost stalls when mowing #1
dambuster
Bangor, Maine
Masset Ferguson 2310
I have a 2310 that almost stalled out while bush hogging...I turn off PTO to mower and literally limp, slowly back to barn. If I try to step harder on forward foot control, it will completely stall out. It is at full throttle....fuel is fresh diesel which I also run in other tractors, just fine. I was mowing just fine for about 30 minutes when this happened. This happened Yesterday as well and started just fine today....and did it again, after a while. I am only mowing light brush and weeds. :confused: Everything seemed fine up until yesterday. Engine idles just fine at all throttle speeds but I have no power to move. Hydraulics?
Any thoughts?
   / 2310 suddenly loses power and engine almost stalls when mowing #2
I have a few here. First would be some sort of clogging/debris in the fuel system that moves/shifts/picks up as you get the machine warm preventing fuel flow once the motor is under load. Secondly I would be curious about hydraulic fluid levels and how freely flowing the system is... Similar to the fuel line concept, a clog would restrict movement and functionality but wouldn't starve the engine until you created a hydraulic demand greater than the engine can withstand (think pushing a loader into a pile and stalking a machine due to demand). Either way if start by checking all fluid levels and filters first before tearing into anything.
Thanks...logical input...I will have a full day tomorrow! Will check hydraulic fluid first...then fuel filter....etc....Will post results later tomorrow!
Thanks
   / 2310 suddenly loses power and engine almost stalls when mowing #4
When was the last time the fuel filter was changed?
The pedal does not act like a automobile accelerator. You lose torque ( but gain speed) the farther down you press it. It can stall is there is a heavy load and the pedal is pushed all the way down, esp. in high range.
Also, by "bush hogging", are using a MMM or a 3pt rotary cutter?
Fuel filter was changed last year, about 50-60 hours ago. I understand about the pedal. I only use low range when cutting. Yes the mower is a 3 pt, 4 ft, rotary brush mower. It seems that the issue is after tractor is warmed up....for example, I expect I would be able to start it now, and mow for a while....then lose power. I do have to dis-engage the PTO otherwise, I would stall completely....and I limp back to my garage....very slowly...
   / 2310 suddenly loses power and engine almost stalls when mowing #6
2 things I would check if it isn't a fuel issue. Excess heat, check the hydro's cooling fan blades. If the 3pt lever isn't centered, it can rob you a lot of power dumping hydraulic oil over the relief valve, but this would probably be noticeable from the 3pt movement.
   / 2310 suddenly loses power and engine almost stalls when mowing #7
Check air cleaner?
   / 2310 suddenly loses power and engine almost stalls when mowing #8
And if everything looks good, and no resolution, before tearing anything apart, or replacing parts, remove the battery, clean the radiator screen, and clean out the radiator fins with a hose.
   / 2310 suddenly loses power and engine almost stalls when mowing #9
Vacuum on the fuel tank?
   / 2310 suddenly loses power and engine almost stalls when mowing #10
Simple question, are you in high mode? Is your brake locked? How many hours?
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
