2310 bleeding fuel system
/ 2310 bleeding fuel system #1
jaybrad
Central Maine
Massey Ferguson GC 2310TLB
This morning I changed the fuel filter, and Tried to follow the instructions in the manual for bleeding the system, but the fuel valve does not seem to work like the one in the diagram.
The manual shows the valve with toward the front (3:00 position) as air bleed, straight down (6:00), toward the back (9:00) as off. However, on mine the on seems to be 6:00, and both 3:00 and 12:00 are off. After going back and forth several times, I eventually got the bowl half full, and it seemed to run OK. But it got me wondering if the bowl should be full, and what is the process for bleeding the system with a valve like mine?
Thanks,
Jay
Sorry for the typo - I Should have added that on mine the 6:00 position is on, just like in the manual. It's the ore two positions that are a mystery.
/ 2310 bleeding fuel system #3
I just changed the fuel filter on my gc2300 Friday and my valve has only a shut off and a on.The manual says it have a bleed as well but have never found it???.I just turn the valve to on and let the pump run untill the bowl is full and then start it up and go.Have done this a few times and have never had any problems.Larry
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
1997 International 3800 School Bus (A64194)
1997 International...
2007 JOHN DEERE 350D LC EXCAVATOR (A65053)
2007 JOHN DEERE...
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
