2305
   / 2305 #1
hillmower
I have a 2305 on my property as a "demo." I like it, but while driving through my horse pasture it beat the heck out of me. It also seemed a little prone to tipping when going through ruts, etc. I am wondering if the rough ride is simply a function of the size of the tractor, or if it is specific to this model.
   / 2305
   / 2305 #3
I went through the same thing when I first moved to the country. I mow about 2acres that used to be pasture. I started out with a GT 235 ( garden tractor ) because of the small tires and relativley light wieght I was bounced all over the place. The following year I traded it in on a 4010 ( I believe the 2305 is it's replacement all thought the 4010 is a little bigger in size) I noticed a great difference in the ride but still was bouncy. This year I traded in the 4010 for the 2520. What a differance!! The larger tiers both in height and width also the extra 400-500lbs really made a difference.I am quite satisfied with the ride now. Can only imagine how nice a 3320 would be???Maybe next year!lol. 2520 is about 1900lbs without the deck on. You may want to consider something a little bigger or end up spending way to much$$$$ to get ware you need to be like I did!!!!
Just MHO!
Good Luck!!
Jamie
   / 2305 #4
Just MHO!
Good Luck!!
Jamie
   / 2305 #5
There is lots of guys on this site who can help you a lot if your more specific about what you plan to do with your new tractor and were you live. They can steer you into something that will be the perfect fit for your budget and needs.
Cheers!
Jamie
   / 2305 #6
Cheers!
Jamie
   / 2305
Thanks, I have about 2 acres of new lawn around my house and about 5 acres of pasture. I need the tractor to mow and for the many projects I have planned for our newly built house. I should also add that the 2305 I tested doesn't have the FEL or mower attached so it is lighter than it will be if I buy one.
   / 2305
   / 2305
Thanks for this info. Approx. how much for the 2520? Also, does the additional height make it seem less stable than the smaller tractors you have had?
   / 2305
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Unused 2025 CFG MX50R Mini Excavator (A49461)
Unused 2025 CFG...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Rhino 156 Chisel Plow - NO RESERVE SELLING ABSOLUTE (A51039)
Rhino 156 Chisel...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
