2305 vs 2320 manuel
/ 2305 vs 2320 manuel #1
I noticed in one of the other post, the 2305 needed the first oil change at 200 hours, below is some copy/paste directly from the Deere site from the online manuals and it appears there must be a missprint, because the 2305 and 2320 have the same engine, where one needs an oil change at 50-hours and another at 200 hours.
Also, I noticed in my manual the tranny on the 2320 needs service every 400-hours after the initial and I assumed the added time (the 2210 manual states every 200-hours) was due to the cooler vs the small fan. However, I noticed in the 2305 manual it states every 400 hours like the 2320 and I question if that is a missprint as well.
2320 Specs shown below.
Engine
Model Number 3TNV76
Type Diesel
Gross Horsepower 17.9 kW (24 hp)
PTO Horsepower 13.4 kW (18 hp)
Cylinders Three
Slow Idle Speed 1300 rpm
Rated Engine Speed 3000 rpm
High Idle Speed 3170 rpm
Operating Range 1270 - 3170 rpm
Cooling Type Liquid
Oil Filter Standard Single Element
Air Cleaner Dry Type, Two Stage
After First 50 Hours
· Change engine oil and filter.
· Change transmission oil and filter.
Every 50 Hours
· Check front axle oil level.
· Lubricate machine.
Every 200 Hours
· Inspect alternator belt.
· Check wheel bolt torque.
Every 400 Hours
· Replace fuel filter.
Every 600 Hours
· Check engine low idle speed.
· Check air filter intake hoses and clamps.
· Change front axle oil.
· Check brake adjustment.
Yearly
· Change engine oil and filter if less than 200 hours of operation.
· Drain water from fuel tank and replace fuel filter.
· Check all hoses and clamps.
· Check battery electrolyte level.
Copy/Paste for 2305Engine
Manufacturer Yanmar
Model Number 3TNV76
Type Diesel
Gross Horsepower 17.9 kW (24.0 hp)
Cylinders Three
Operating Range 1170 - 3170 rpm
Cooling Type Liquid
· Clean transmission suction screen.
Every 50 Hours
Every 200 Hours
Every 400 Hours
Every 600 Hours
Yearly
/ 2305 vs 2320 manuel #2
Looks like the oil change at 50 hours is a misprint online (you should change at 50 and then at 200 or yearly, whichever comes first) but the transmission oil and filter change info is correct (at 400 hours after changing at 50 hours).
From my print version (came with the tractor) John Deere 2305 manual starting on page 31 "Service Intervals":
After first 50 Hours:
Every 50 hours:
Lubricate machine
Every 200 hours:
Every 400 hours:
Replace fuel filter
Every 600 hours:
Check Engine low idle speed
Yearly
Every 1200 hours
Check engine valve clearance (see your JD dealer)
Every 2 years or 200 hours
Flush and replace factory coolant
Service fuel injection nozzles
/ 2305 vs 2320 manuel #3
The tag under my hood says first oil change at 50 hours then every 200
/ 2305 vs 2320 manuel #4
I'm confused. Therefore, I've been changing my engine oil every 50 hrs (the dealer did a full service at 50) and plan on changing my hydrostatic filter and fluid at 200 hrs, and then every 200 thereafter. After seeing all the typo's in Deere literature, you would think they would ask members of a forum such as this to proof-read this stuff for them --- obviously the techno-guru's they employ can't see beyond their own designs --- plus, I wonder if there are "language" barriers . . .
The hour service on the transmission for the 2305 may be correct, but I still question whether the 400-hour interval is correct, because the 2305 transmission wise is really no different than a 2210 and in that book it's stated to be every 200-hours.
I just noticed on the 2520 was similar to the 2305 in that the first oil change is at 200-hours.
First oil change is at 50 hours for the 2305, not 200.
Scott
Agree totally, but I wonder if the 400-hour service is a misprint on the tranny, because it's double the length compared to the replacement unit, 2210 (every 200-hours).:confused:
/ 2305 vs 2320 manuel #9
gosh 200 seems like ALOT! :confused:
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
