2305-utility tractor- won't stay running without attaching jumper cables to it!
   / 2305-utility tractor- won't stay running without attaching jumper cables to it!
When I went to install the voltage regulator, only to learn that there is more than one to choose from for a 2305, I noticed that the connection was horribly corroded. It looked equal to the worst battery connection I have seen in my limited exposure. I cleaned it with a toothbrush and electronics cleaner and continued to mow the lawn. Usually, after mowing the lawn it won't start after I turn it off. This time it did and also started on it's own the next day, yesterday.
I checked the battery with the tractor running and it read 12.2 the same after I turned it off.
   / 2305-utility tractor- won't stay running without attaching jumper cables to it! #42
Hopefully you have it fixed. Thanks for coming back and telling us what you've found out. Keep us posted if anything else happens.
My grass is getting tall, bear with me.
Today is the day. I replaced the voltage regulator and the voltage meter is now reading 13.25 while idling.
Finally, success!
Many thanks to everyone who helped me along the way, it was a long ride!
Thank you all again.
The additional power this has now is a very good thing! What a difference!
   / 2305-utility tractor- won't stay running without attaching jumper cables to it! #46
Finally, success!
Thanks for coming back and letting others know the fix.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2008 HONDA ODYSSEY VAN (A57192)
2008 HONDA ODYSSEY...
2022 Ligchine Spiderscreed Concrete Screed (A55851)
2022 Ligchine...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
