2305-utility tractor- won't stay running without attaching jumper cables to it!
   / 2305-utility tractor- won't stay running without attaching jumper cables to it!
When I went to install the voltage regulator, only to learn that there is more than one to choose from for a 2305, I noticed that the connection was horribly corroded. It looked equal to the worst battery connection I have seen in my limited exposure. I cleaned it with a toothbrush and electronics cleaner and continued to mow the lawn. Usually, after mowing the lawn it won't start after I turn it off. This time it did and also started on it's own the next day, yesterday.
I checked the battery with the tractor running and it read 12.2 the same after I turned it off.
   / 2305-utility tractor- won't stay running without attaching jumper cables to it! #42
Hopefully you have it fixed. Thanks for coming back and telling us what you've found out. Keep us posted if anything else happens.
My grass is getting tall, bear with me.
Today is the day. I replaced the voltage regulator and the voltage meter is now reading 13.25 while idling.
Finally, success!
Many thanks to everyone who helped me along the way, it was a long ride!
Thank you all again.
The additional power this has now is a very good thing! What a difference!
   / 2305-utility tractor- won't stay running without attaching jumper cables to it! #46
Finally, success!
Thanks for coming back and letting others know the fix.
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
John Deere 270A Backhoe Attachment (A53317)
John Deere 270A...
(2) HYD CYLINDERS (1) 3" X 24" & (1) 3" X 12" (A57192)
(2) HYD CYLINDERS...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
NEW Woods 6ft Finish Mower (A57024)
NEW Woods 6ft...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
