2305 Removing FEL
   / 2305 Removing FEL #11
flyngti said:
I remember being utterly amazed at how easy it was when the dealer removed the FEL in the yard. I've not tried it yet by after reading this post, I'm going to try it when I get home!
I think it's a good idea to get familar with removal and re-install of the loader.
Just have your manual with you and go step-by-step. First time will be slow...and no worry about that!
You'll pick up speed after you do it a couple times.
   / 2305 Removing FEL #12
I've got the same loader (on a 2320) and am new to this as well. Even for me its easy. One question for you experienced guys...I've noticed a small amount of hyd fluid dripping on my mower deck when the FEL is attached. Where all the lines attach, some amount must be leaking. Is that common or is that a red flag. Its not much fluid, I can wipe it up with a rag, but I just don't want to hurt my new JD.
Thank.s
   / 2305 Removing FEL #13
cast_and_blast said:
Only a few additions - you may need to put some down force on the loader in the initial step (i.e. lift the front-end of the tractor off the ground a bit) to get the loader locks to flip easily. Back up the tractor a bit after the loader is off but the hydro lines are still attached (I'm talking less than 1 foot) - this helps make it easier to move the whole bundle of 4 hydro lines as they are usually in a "ring" for routing - gives you clearance between the foot platform and the loader. Also, set the parking brake before getting off the tractor to unhook the lines - if it rolls back it could pop the hydro lines.
It's quick and easy!
Scott
this is the best advise. Lift the front wheels off, pop the tops and let it ride back. easy as pie.
   / 2305 Removing FEL #14
Thank.s
Disconnect and reconnect the hydraulic lines. That might fix the problem.
It could be a bad QD but doesn't sound like it's leaking bad enough to get it back to the dealer.
If disconnecting/reconnecting doesn't fix it, I'd just keep an eye on it until your first service, then let the dealer replace the line, if necessary. That's assuming if doesn't get much worse.
   / 2305 Removing FEL #15
To add to what Roy says -
When you connect or disconnect your hydraulic lines, you will always loose a little bit of fluid as the ball in the end of the fittings depresses to make the connection as you are pushing them on or taking them off. This little bit of fluid may lay in the fitting, and drip out. If you are getting 6-8 drips worth of fluid on your deck, that is normal.
And as Roy points out, one of your fittings might not be properly seated - removing and replacing them will fix that.
Also, when the hoses are disconnected, use a clean rag to wipe both the male and female ends of the fittings - a little bit of dirt can also cause a problem. Do not try to push the balls in on the fittings while cleaning!
   / 2305 Removing FEL #16
Thank.s
I had the same issue when I first got my 2305. The leak was coming from the transition from the hard line to the soft hose. I discovered that the dealer had not tightened the nuts at that connection. This caused me to go over the entire tractor with a wrench...lots of loose nuts and bolts. Not to mention there wasn't a drop of fluid in the bush hog gear box! Make sure you check everything for tightness.
   / 2305 Removing FEL #17
Yes! I keep a clean rag wrapped around the end of the bundle of 4 hydro lines and then lay it on top of the loader arm. This way, the clean rag is always there when connecting or disconnecting.
Dirt and hydro fluid is not a good mix. ;)
Scott
   / 2305 Removing FEL #18
"This little bit of fluid may lay in the fitting, and drip out."
So true... I keep a set of latex gloves next to my box o' shop rags for removing/installing the QDs. I don't mind the work, but I hate to get dirty - especially with hyd oil!!
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
2014 Vermeer BC1000XL S/A Towable Chipper (A55787)
2014 Vermeer...
2004 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2004 Ford F-250...
2016 Ford F-150 4x4 Crew Cab Pickup Truck with Liftgate (A55788)
2016 Ford F-150...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
2014 Walker Compactor (A55787)
2014 Walker...
