2305 PTO
   / 2305 PTO #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
It appears that you can't operate a chipper with a 2305 because there is no override for the seat saftey switch which turns off the PTO if you're not on the seat.
Do folks use the "Big Brick in the seat" method, or is there an easier way to deal with this issue. Anyone installed a switch that circumvents the seat safety if it's switched on?
Cliff
   / 2305 PTO #2
I jumpered the 2 pairs of wires on my 4010 to allow the under seat button to be used. However, most of the time, I just tie a tension cord from one side of the ROPS across the front of the seat back to the other side of the ROPS. This way, I can raise the chipper/shredder and go to another bunch of brush without having to shut the PTO off.
This tension cord is used to hold the PTO shaft up and out of the way on the chipper/shredder when it is stored. So, it's readily available when I hook up the machine to the PTO.
Ralph
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2012 BROCE BROOM (A50854)
2012 BROCE BROOM...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
