2305 mmm independent hydrallic lift
   / 2305 mmm independent hydrallic lift #21
i dont know bout you all, but I dont have any problems with my MMM and quick hitch at all. If I want to use 3pt, i lock deck w/dial.
If I want to mow, I lower rockshaft fully, (to lower deck and 3pt) then pull the rockshaft lever for a quick second. The 3pt hydraulics on mine raise the 3pt before the MMM, and whooola the deck is mowin and the quickhitch is raised!
Id only think of Independent Lift if I didnt have a FEL....
   / 2305 mmm independent hydrallic lift #22
I have the independant lift, no fel yet. my tractor was a demo unit that had the indy lift on it, otherwise I probably would not have got it. as far as imatch dragging in the ground, I don't have that issue even with the 3pt all the way down it's 4 or 5 inches off the ground.
   / 2305 mmm independent hydrallic lift #23
I got the hoses reconnected today for the FEL, switching from the independent lift. I wasn't releasing/equalizing all the pressure in the hydraulic control. I went out this morning and moved the lever around about five times in each direction, bend down and reconnected the hoses for the FEL with no trouble.
   / 2305 mmm independent hydrallic lift #24
I installed mine myself and it was pretty easy but I do most of my own work. I needed it because I have a dump grass catcher that mounts to the three point arms and needed so I could raise and lower the mmm with out the three point arms moving. It is a pain to change hoses when both the mower and loader are both on the tractor but I do not run the tractor with both installed very much though.
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
80" X 16' DBL AXLE TRAILER (A54756)
80" X 16' DBL AXLE...
2005 KOMASU D39PX-21 CRAWLER DOZER (A52705)
2005 KOMASU...
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A54865)
2006 Volvo VNM...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
