2305 Help re fuel problem
   / 2305 Help re fuel problem #1
Thomberd
Birkenfrld,OR
John Deere2305
2305 runs grat even under load for about ten minutes, then aabruptly shuts doown. Restarts, aafter five or six ignition trials, then runs perfectly for another ten minutes. Beewnz all thru the fuel system several times, have drained the tank, put in fresh filters, bled the system repeatedly, the engine behaves the same after everything. what does everybody else know Aabout this but me?
   / 2305 Help re fuel problem #2
Check that your fuel cap vent isn't plugged. Try running it with the fuel cap loose to see if it makes a difference. Also, when it shuts down, open the fuel cap and listen if you are getting a rush of air.
Thanks, will try this !
Fuel cap replaced and stlll not runningmore than 20 minutes! Any other ideas$.
   / 2305 Help re fuel problem #5
Since you say the engine shuts down abruptly, I would start looking at the safety switches starting with the seat switch. I've never done that diagnosis so can't help. I'm sure others have and hopefully will be along to to help you out.
   / 2305 Help re fuel problem #6
I also have a JD 2305 that does the same thing. Have done all the things you said you have done plus took the seat switch out. Still looking for problem.
TEST BID LOT (A50775)
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2018 Lexus IS300 Sedan (A48082)
2018 Lexus IS300...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
