2305 changing transmission oil/filter?
   / 2305 changing transmission oil/filter? #1
EasyE
North Carolina
JD 2305
It is recommended in my service manual on my 2305 to change transmission fluid/filter and clean the suction screen @ 50 hours. I bought this machine last Dec. and I only have about 12 hours on it at this time. My question is two fold, at the rate I am going with hours should I change it before the 50 hours, and is this something simple I can do myself? Looking at the manual it looks pretty simple but, I know how these simple projects can turn in to nightmares.
   / 2305 changing transmission oil/filter? #2
EasyE--first let's assume (I hate to, but..) that it's the same as a 2210. It is pretty easy to do--do a search on 2210 changes. The biggest challenges are: 1)getting a big enough drain pan for all of the hydraulic fluid, and 2)getting the screen assembly off--many have found it easier to remove the 3 bolts at the top of the assembly (follow the metal tube up about 6 inches) and then remove the entire thing--this makes it easier to get the suction screen out as well.
BTW--if you plan to do oil change early--read up on the threads about break-in oil--lots of discussions on if required etc., you need to decide for yourself /forums/images/graemlins/confused.gif
   / 2305 changing transmission oil/filter? #3
Agree with the above, the process is not too bad. As for time, I would encourage you to stick to the 50-hour period (that is a special break in oil designed for the initial break in period) and then from that point on, either do it yearly or every 200-hours. Personally, I like to do mine every 6-months after the break in period, somewhere in the heart of summer and just prior to winter for snow removal and both changes are around 50-hours of use.
</font><font color="blue" class="small">( EasyE--first let's assume (I hate to, but..) that it's the same as a 2210. It is pretty easy to do--do a search on 2210 changes. The biggest challenges are: 1)getting a big enough drain pan for all of the hydraulic fluid, and 2)getting the screen assembly off--many have found it easier to remove the 3 bolts at the top of the assembly (follow the metal tube up about 6 inches) and then remove the entire thing--this makes it easier to get the suction screen out as well.
BTW--if you plan to do oil change early--read up on the threads about break-in oil--lots of discussions on if required etc., you need to decide for yourself /forums/images/graemlins/confused.gif )</font>
Fish- I have no idea if it is the same as the 2210, this is my first tractor. Thanks for the input.
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
Swict 66" Bucket (A50121)
Swict 66" Bucket...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
43002 (A51691)
43002 (A51691)
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
