2305 100 Hour service
   / 2305 100 Hour service #11
Deadman said:
200 Hrs is INSANE for the engine oil. That poor engine barely holds 2 quarts of oil. That oil will be junk when and if you would ever reach 200 Hrs. My dealer told me to change the oil at 20 hrs, and re-install BREAK IN OIl. I did that so it doesn't burn oil as it ages.
My dealer also has a 2210 and he changes the oil every 20 Hrs and the Oil filter every other change. Its simple to understand why when You see how little oil is in the motor. I change every 25 hrs and every other on the filter.
I agree Deadman, I'm just telling you what the manual reads. It being under warranty I would think they would want you to change it sooner myself. I spoke to the dealer and he suggested every 50 hours.
   / 2305 100 Hour service #12
Remember you can buy the "break-in oil" if you want to change the oil and put that back in. Its available at the dealers.
I just know that the oil in my 2210 comes out like TAR after 25 hrs. :eek:
   / 2305 100 Hour service #13
Deadman,
Is your tractor operating up to sufficent operating temperature, or a little on the low side?
Do you know the sulfur content in the fuel you are burning?
Both would make for dirtier oil than what is considered normal.
Diesels tend to get nastier looking oil than gas burners, anyway.
Many years ago, while taking an automotive class at a local college, we viewed an oil study from another college. It suggested oil actually gets better from use, not worse. The problem, and reason for us changing the oil, is the dirt, which gets into it.
During WWII, airplanes were put on an oil filter change/top it off and send it back out schedule, to conserve oil, and still maintain the airplane engines.
David from jax
   / 2305 100 Hour service #14
While it is true that the owners manual does not mention an engine oil change untill 200 hours, I think it is a typo. Look under the hood and you will see that the service intervals are on the decal and it includes the initial engine oil and filter change at 50hrs. , then every 200. i did mine at 52hrs. and I will do it once a year as I will only be averaging about 75 hrs a year. I did not reinstall break-in oil. No one in my dealers service dept (and they are very knowledgable) thought that that was required, or even a good idea.
I think the idea here is to get the contaminates which are inherent to the manufacturing process of the engine as well as the small filings and debris which are a by-product of engine break-in, out of the engine.
   / 2305 100 Hour service #15
My 2305 manual clearly shows the first oil change to be at 50 hours. It then goes on to show oil changes at every 200 hours or yearly, whichever comes first.
I believe it's on page 31.
Scott
   / 2305 100 Hour service #16
Scott
Mine is on page 32 and at the top it says After first 50 hours: Change "transmission" oil and filter. It doesn't mention the "engine" oil until 200 hours. Could it be we have two different manuals?
   / 2305 100 Hour service #17
OK, I'm surely confused....my manual does not indicate an oil change until 200 hours AND on page 36, bottom of left hand column says "Do not use break in oils".
I plan on changing at 25 hours and probably use a 5 w 40 Mobil 1 synthetic oil.
   / 2305 100 Hour service #18
bigreddmax, it's easy to do, just be prepared for the first time, the filter is going to be a B*#**. Other than that it's OK. I will probably change mine more often than required.
   / 2305 100 Hour service #19
Just change it often. It takes 3 quarts and a filter. That's 9 bucks.
132984 (A54865)
132984 (A54865)
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
2012 BMW 328i Coupe (A55758)
2012 BMW 328i...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
Valtir Truck Mounted Attenuator (A55787)
Valtir Truck...
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
