2300/2310 FEL Pallet Forks?
   / 2300/2310 FEL Pallet Forks? #1
mvanhaerents
S.E. Michigan
Deere 4410
Does anyone know if the 2300/2310 FEL (2350) shares the same attachment pin sizes and locations as any other loaders? I'm interested in purchasing an ATI pallet fork attachment for my loader, but they don't list it as a fitment option. Currently, I'm not sure if I will only buy the pallet fork attachment, or the quick attach system w/ a universal pallet fork setup. Either way, I need to know the attachment specs.
   / 2300/2310 FEL Pallet Forks? #2
When I bought my ATI toothbar for our GC2310 - I ordered one for a Kubota BX23 series. I think the buckets are very similar. Call up the ATI sales rep. - I am sure he can help
Just an update: I bought a pin type pallet fork setup from my dealer that was intended for the MF 1500 series tractor. I then cut the frame, and shortened it by ~6 inches. I also had to drill and weld lower pin mount locations as they are different on the 1500 series tractors. They have worked great for the last year.
   / 2300/2310 FEL Pallet Forks? #4
Can you post any pics? I am considering building crates for handling my firewood and a set of pallet forks will be required.
Thanks!
   / 2300/2310 FEL Pallet Forks? #5
Horst Welding have a direct fit set of forks available. Work like a charm.
   / 2300/2310 FEL Pallet Forks? #6
Thanks for the info, I will check them out. Is it difficult to switch back and forth between the forks and bucket using the pins?
   / 2300/2310 FEL Pallet Forks? #8
I keep everything on dollies and a concrete floor. So it only takes a couple of minutes to change back and forth. Good excuse to make sure the pins are greased.
   / 2300/2310 FEL Pallet Forks? #9
FYI the Horst Welding Pallet forks are $750 (+ tax and delivery)
I wont be using them enough to justify spending that much.
Maybe it is time to start fabricating my own.....
   / 2300/2310 FEL Pallet Forks? #10
On a MF1523 equiped with the MF Pin Lock Quick Attach, and switching between bucket and folks, it takes around 35 seconds - I timed it for ya!
EanJay
CFG Industrial MH12RX (A50121)
CFG Industrial...
2008 Ford F-250 4x4 Pickup Truck (A50323)
2008 Ford F-250...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
