22NF battery update
   / 22NF battery update #1
Rob-D
Veteran Member
Catskills
John Deere 3320
In case anyone is interested JD has replaced the original 22NF battery that was causing problems in the compact tractors. My new tractor has the updated 22NF with an overflow tube that runs out the bottom of the tractor.
The battery still says 22NF but it also has a number on it LVA15187.
While I have always had good luck with Deere batteries in my machines the leaking 22NF was a pain.
One more thing before you go out and buy a new battery because you think yours is bad make sure to check the voltage at the battery terminals before pulling the battery.
Rob
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
2006 FORD F-750 XL 4X2 SUPER DUTY CRANE TRUCK (A51406)
2006 FORD F-750 XL...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2000 POLARIS MAGNUM 325 4-WHEELER (A51406)
2000 POLARIS...
1983 Case 580D (A47477)
1983 Case 580D...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
