225 running hot
/ 225 running hot #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
Tractor runs hot in about 30 min of hard use. I have been running a rotary cutter a lot and I know it puts a lot of debris in the system.I clean the screen often and blow and wash the radiator when I get home. Plenty of coolant and the fan is working. I still feel like I am not getting enough airflow. Anybody cracked the code on this?
/ 225 running hot #2
What speed range are you running in? If traveling in Mid or High at 1/2 pedal stroke or less, try dropping down to next lower range at full pedal. This will give equal trave speed but require somewhat lower HST pressure plus move more oil through the system resulting in cooler hysraulic temperature at the cooler. Hotter the oil cooler is, means warmer the air is passing through the radiator.
Just a thought, but worth a try.
/ 225 running hot
You just confirmed part of my problem. I have a hydraulic leak and was running low on fluid. less fluid means less cooling means more heat to deal with means hotter temps.
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
